iamgeorge
Apr 21, 2021Guide
Wired Backhaul on MK62
Hi, I purchased MK62 a few months back and have been using it since then. But wifi signal keeps droping at time to time since both router and satellite are using wireless backhaul. According...
Apr 21, 2021Guru - Experienced User
iamgeorge
Apr 21, 2021Guide
Hi,
How can you confirm?
Where can I find the firmware update details.
- plemansApr 21, 2021Guru - Experienced User
How can I confirm?
1. the article specifically lists those models.
2. I've had others on here using a wired backhaul
3. You can read through the release notes on the firmware if you'd like. I didn't because there's been so many firmware releases.
4. You can always move the satellite next to the router and connect it with a short cable to test it if you'd like. when you connect it, leave it for at least 5 minutes before checking backhaul status
- iamgeorgeApr 21, 2021GuideBut how to check the back haul status?
Sadly that one I can't tell you.
I know how with the Orbi systems but I've never used the MK systems so I'm not sure how it displays the backhaul in the settings display.
And there aren't many people on here who help out with the MK systems.
Maybe Christian_R or DarrenM or ChristineT could help with that.
