NK1
Dec 07, 2023Tutor
Wireless devices connected to same AP can't see each other
I have and MR60 and two MS60. If two wireless devices are connected to the network via the MR60 they can not see each other / connect to each other / access each other. However both devices can be s...
- Dec 20, 2023
Well I decided to do some additional testing today. I shut down all the MS60 and disconnected the MR60 from the switch. And still all devices wirelesses connected o it had issues. So clearly an issue with the MR60 and how it is routing things.
I spent time going through settings, and found the culprit (though I think it is a different culprit than last time as I don't recall ever messing with it).
under Advance->Security->Access Control "Turn on Access Control" was checked, rule was set to "allow all new devices to connect" all devices listed (wired and wireless) were set to allowed.
So nothing obvious that it would be the culprit, but I went I'm testing things...
So I unchecked it and thus disabled Access Control and now all devices connected wirelessly to to MR60 can see see each other.
NK1
Dec 21, 2023Tutor
Yes, all of them are on that firmware
As I stated, I found the problem it's the "Access control" it was turned on, and for whatever reason when it is on it blocks communication between wireless devices who are both connected to the MR60 but not with wired devices or any wireless devices connected to an MS60. Though nowhere does it seem to indicate that this would behave in such a way. I'm guessing the default state is it for it to be off, so most do not encounter this issue. And with the way the settings it had it wasn't restricting any devices from connecting, so no need to be on, so turning it off causes no issue and fixed the issue I was having 🙂 while I could try and figure more out about it, and am curious why that setting caused this behavior, for now I am done with it until it starts messing up again...
Dec 21, 2023Guru - Experienced User
One other possibility is that for MK systems and Orbi MESH systems, they don't seem to like IGMP or Green Ethernet protocols that are seen on some Managed switches. Some have been able to disable these and has resolved some ethernet connected satellite issues seen with manages switches. Otherwise, it's recommended to use non managed switches between the MR and MS if the MS are ethernet connected. I've had my 60 series connected before and haven't seen any issues in between them. NG GS-105/108v4 and GS308v3 series switches work for Nighthawk mesh systems
