Chauncey
Mar 07, 2021Aspirant
Wireless printer compatible with Netgear Nighthawk Mesh WiFi 6 System
I just installed Netgear Nighthawk MK63 AX1800 Mesh WiFi 6 system to solve my WiFi issues I has having thru-out my house. Now my old HP wireless printer will not connect dispite everything I have tr...
antinode
Mar 07, 2021Guru
> [...] Now my old HP wireless printer [...]
Not a very detailed description of that device.
> [...] will not connect dispite everything I have tried. [...]
"will not" is not a useful problem description. It does not say what
you did. It does not say what happened when you did it. As usual,
showing actual actions (commands) with their actual results (error
messages, LED indicators, ...) can be more helpful than vague
descriptions or interpretations.
How many people on this planet, would you say, have any idea what
"everything I have tried" actually entails? Or what "will not connect"
means to you?
Everything other than your printer works as expected?
Is the problem getting the printer to communicate with the router, or
getting some (unspecified) computer/device to communicate with the
printer, or what, exactly?
> [...] Is there a wireless printer out there that I can easily install
> & continually work with this WiFi system?
Not knowing why your (unspecified) "my old HP wireless printer" is
not working, I wouldn't hazard a guess. I wouldn't bet that any other
printer would do any better.
You might start at hp.com, get the instructions for your printer,
resd them, and follow them.
- ChaunceyMar 07, 2021Aspirant
Is there a wireless printer out there that I can easily install & continually work with this WiFi system?
- antinodeMar 07, 2021Guru
> continually work with this WiFi system?If _I_ repeat all _my_ questions and suggestions, do you think that
_I_ will get a better response?
