ChrisStanleyy
Aug 18, 2021Aspirant
Wondering on how to reset my login details to the Nighthawk app. EX6250
I am just wondering on if i can reset my log detalils (admin login). Cant remember the password I put and i really dont want to reset the extender again just to login,
Is there anything i can do???
1 Reply
I dont' have that specific model but some had a password recovery that you could try.
If that doesn't work (or you didn't setup) then you would need to factory reset to get back in.
