RK85's avatar
RK85
Follower
Apr 16, 2021
Wrong password
I set up my router according to the instructions on the app. I can see the WiFi network on my devices but when I use the password provided it says wrong password. I’m using the password printed right on the router
1 Reply
  • plemans's avatar
    during setup, did you change the wireless ssid or password?
    Was it a renewed/refurbed/returned products?
    If so, maybe it was changed from stock. You can try resetting it back to factory
