Cola-Coffe
Nov 03, 2020Aspirant
Xr300 + mesh
Can i use xr300 as main router and somehow connect mr60 mesh to same wifi ? It isnt possible go have different ssid för 2.4 ans 5ghz on the mr60 mesh. Often problem ro cast to Chromecast ans i belie...
- Nov 04, 2020
You can connect the XR300 to the MR60 system but not integrated. The XR300 isn't a mesh router.
You'd probably want to go:
XR300 (in router mode)------>MR60 (in access point mode)
This would prevent a double nat situation.
you'd want to name their wireless ssid's something different from each other as well as ensure they aren't on the same wireless channels. this would prevent interference.
Nov 04, 2020Guru - Experienced User
Cola-Coffe
Nov 11, 2020Aspirant
Yes this works better Thx. I connected the Chromecast to 5ghz ssid from xr300 and let other devices use other ssid from mr60 mesh .
To bad you can't har different ssids on mr60 mesh
