WacoJohn
Nov 13, 2019Luminary
.APPLE???
Never noticed until now because they are hidden. See screenshot: Uhm ... this is a Windows shop. No Apple iron or s/w on it. This is a partial shot of W10-64 Explorer .... Readyshare d...
- Nov 14, 2019If you've recently plugged it into the router it may have been created to ensure its accessible via ReadyShare on Mac or Windows.
WacoJohn
Thank you for the reply. Here is the attachment .... I hope.
Netduma-Fraser
Nov 14, 2019NetDuma Partner
Ah I see. I believe this is because the drive is compatible with both Mac and Windows but require different files in order to work properly. Reason they're hidden is so you don't delete them and then essentially remove compatibility with Mac or Windows. It's nothing to worry about.
- WacoJohnNov 14, 2019Luminary
I thiink that is a great answer ... makes sense. I have some programs which scan filenames/folders, .. even hidden ones. I run them often and until the last couple of days, did not notice these files/folders in those scans. So, I unhid them to investigate. Also, the creation date is pretty new. While your answer makes a lot of sense, ... just wondering if we are right. Why would they so suddenly present?
Thank you again. Maybe someone else can explain.
- Netduma-FraserNov 14, 2019NetDuma PartnerIf you've recently plugged it into the router it may have been created to ensure its accessible via ReadyShare on Mac or Windows.
Gonna go with that. I had not recently plugged in the drive when I first saw these folders. Maybe Duma updates itself(??) When I checked for updates there were none.
In any case ... it's my job to worry ...[ : >) Thank you for the time. Going to mark you Best Answer right after I post this.
