Alewi
May 18, 2020Apprentice
10g port quistion
Hi netgear community, I have fiberglass internet and I don't want to use the standard modem from my isp anymore. I would like to buy a 10gb port adapter, so I can plug the fiber cable directly to the...
Netduma-Fraser
May 18, 2020NetDuma Partner
So you want to use the SFP port correct? Usually you need to have it connected to a modem or router but in theory with the adapter it could work. Give it a try and then let us know what happens.
