barcallin
Apr 16, 2020Guide
2.3.2.56 FW Version
Just purchased an XR450 and had to RMA my first one because it would not get ip address from modem and after a factory reset it picked one up and then dropped. Got my new one today and started exper...
- May 03, 2020I'd recommend you downgrade back to the firmware that works for you and then wait for the new firmware where that shouldn't be an issue.
Netduma-Fraser
Apr 21, 2020NetDuma Partner
So just to clarify, you've tried previous firmware versions and you don't experience this issue? If you set the router to use a static IP in Internet Setup and then reboot does that keep it connected?
