barcallin
Apr 16, 2020Guide
2.3.2.56 FW Version
Just purchased an XR450 and had to RMA my first one because it would not get ip address from modem and after a factory reset it picked one up and then dropped. Got my new one today and started exper...
- May 03, 2020I'd recommend you downgrade back to the firmware that works for you and then wait for the new firmware where that shouldn't be an issue.
barcallin
Apr 21, 2020Guide
That is correct currently running 2.3.2.40 and the issue does not occur. As soon I as I upgrade to 2.3.2.56 it does not retain the ip address. No I have not tried setting the ip address statically. I can try later tonight and see what happens.
barcallin
Apr 21, 2020Guide
So I upgraded to the lates firmware again and the router got an ip address and worked fine. However, after doing a release and renew it refused to pick up and an ip address. I entered a static ip address did not make a difference. I had to downgrade all the way to 2.3.2.32 to get the router working again and then upgrade back 2.3.2.40.
- FURRYe38Apr 22, 2020Guru - Experienced User
I have my XR450 connected to a CM1100 and it's using v56 FW...
barcallin wrote:So I upgraded to the lates firmware again and the router got an ip address and worked fine. However, after doing a release and renew it refused to pick up and an ip address. I entered a static ip address did not make a difference. I had to downgrade all the way to 2.3.2.32 to get the router working again and then upgrade back 2.3.2.40.
- barcallinApr 22, 2020Guide
SURFBoard SB6190 HW ver.3 SW ver. 9.1.93V
Spectrum ISP
I own the modem
One thing I notice with the XR450 router, you have to power OFF or Reboot the ISP modem before the XR correctlly handshakes with the modem correctly and the Internet LED finally turns WHITE.
Be aware of your 6190 modem:
