barcallin
Apr 16, 2020Guide
2.3.2.56 FW Version
Just purchased an XR450 and had to RMA my first one because it would not get ip address from modem and after a factory reset it picked one up and then dropped. Got my new one today and started exper...
- May 03, 2020I'd recommend you downgrade back to the firmware that works for you and then wait for the new firmware where that shouldn't be an issue.
barcallin
May 02, 2020Guide
So I had to reboot the router and I was dead in the water. Since other ppl are on that firmware and are not having any issues. Im guessing the firmware has an issue with modem. Not sure what it is but that firmware just does not work for me.
Netduma-Fraser
May 03, 2020NetDuma Partner
- barcallinMay 03, 2020GuideYeah that is what I am doing. Thanks for the help everyone.
