docholiday999
Jan 09, 2023Aspirant
2.4 Stops working
I have been dealing with the same issue. Here is my log file; I just restarted the router yesterday because it was having this issue. XR1000 running firmware v1.0.0.64_1.0.49.
You can see sev...
docholiday999
Should not need to provide static MAC assignment for wifi to work correctly... This needs to be addressed and reported as a bug
Jan 09, 2023Guru - Experienced User
I recommend you factory reset and setup from scratch.
If you won't try the suggestions, then you'll need to contact NG support and let them know:
https://www.netgear.com/about/contact-us/
Arris DOCSIS is not a model.
I've not seen this on my XR1000.
