TDS21
May 26, 2020Follower
2.4 Wifi drops intermittently on Nighthawk X4S
Hello, wondering if anyone has the same issue on firmware v1.0.1.56. 2.4ghz signal drops and rejects any connection for 10-15mins before it recovers. 5ghz signal works fine though. Very annoying ...
May 26, 2020Guru - Experienced User
Did you try a factory reset after the firmware changes? And then manually resetting the device back up? Not using a backup configuration?
