Woodshopguy
Mar 05, 2018Aspirant
2 ISP provided IP Addresses
I'm am considering a purchase of a pro gaming router. I'm looking for some assistance with which one to get. Currently my ISP provides me with 2 static IP addresses. One for my gaming and 1 for my...
Netduma-Fraser
Mar 05, 2018NetDuma Partner
Hi Woodshop, so to clarify you want a router that can handle two separate WAN connections instead of using two separate routers - 1 for each connection?
Woodshopguy
Yes, one router, that is because the ISP is not providing 2 cables to the wan, just 2 static IP addresses on the one WAN cable.
