TheMattMan
Jul 21, 2019Guide
2 lights white 2 lights Amber xr500
I recently bought a XR500 router and the two connected computers always show a flashing white lift and my ps4 and lg oled tv always show a flashing amber light. It’s seems the tv gets kicked off netwo...
Jul 21, 2019Guru - Experienced User
LED colors are a indication of speed of the connection between the router and devices connected. Amber means that the speed is 100mb while WHITE is 1000Mb.
Be sure your using good quality LAN cables. CAT6 is recommended.
- TheMattManJul 22, 2019GuideI bought all new cat6 cables and still have the same lights. The colors follow the devices if I change where they are plugged in. Everything is within 10’ of router
- FURRYe38Jul 22, 2019Guru - Experienced User
You don't happen to have a external Gb network switch do you? Something you could connect between the router and your devices?
https://www.netgear.com/support/product/GS105.aspx
Sounds like something is possibly wrong with your devices...If these are the only ones doing this.
- TheMattManJul 22, 2019GuideNo switch, spectrum supplied arris modem connected to router.
- schumakuJul 22, 2019Guru - Experienced UserOf course the white or amber LED does follow the device - these are not Gigabit Ethernet capable devices, so the speed negotiates to 100 Mbit/s or even 10 Mb/s - and this amber LED is indicating the lower link speed. Can't see anything wrong here - this was mentioned above already...
- TheMattManJul 22, 2019GuideIt is a Arris modem model TG1672G
I will have to get a switch as I do not have one. My PS4 should be better than 10/100 and even so I am only getting around 30mb dl with a 115mb connection, with nothing else running. I gave the ps4 priority.
