TheMattMan
Jul 21, 2019Guide
2 lights white 2 lights Amber xr500
I recently bought a XR500 router and the two connected computers always show a flashing white lift and my ps4 and lg oled tv always show a flashing amber light. It’s seems the tv gets kicked off netwo...
TheMattMan
Jul 22, 2019Guide
I bought all new cat6 cables and still have the same lights. The colors follow the devices if I change where they are plugged in. Everything is within 10’ of router
Jul 22, 2019Guru - Experienced User
You don't happen to have a external Gb network switch do you? Something you could connect between the router and your devices?
https://www.netgear.com/support/product/GS105.aspx
Sounds like something is possibly wrong with your devices...If these are the only ones doing this.
- TheMattManJul 22, 2019GuideNo switch, spectrum supplied arris modem connected to router.
- FURRYe38Jul 22, 2019Guru - Experienced User
What is the Mfr and model# of the ISP supplied modem?
Can you try putting in a external switch and see if the problem remains? The switch may know similar indications of 100Mb vs 1000Mb connection rates.
