TheMattMan
Jul 21, 2019Guide
2 lights white 2 lights Amber xr500
I recently bought a XR500 router and the two connected computers always show a flashing white lift and my ps4 and lg oled tv always show a flashing amber light. It’s seems the tv gets kicked off netwo...
TheMattMan
Jul 22, 2019Guide
It is a Arris modem model TG1672G
I will have to get a switch as I do not have one. My PS4 should be better than 10/100 and even so I am only getting around 30mb dl with a 115mb connection, with nothing else running. I gave the ps4 priority.
Jul 23, 2019Guru - Experienced User
Do you know if the modem is bridged or in router mode? Your modem already has a built in router. Though this shouldn't effect the connection rate between the XR router and your two devices...
The PS4 is 1000mb supporting. Not sure about the TV. Something to check with the TVs mfr about.
A check with the PS4 connected to the ISP modem if it's in router mode and speed test there to see if the speed is better or the same.
