Willkapps
Jan 22, 2023Follower
2nd router
I switched to the xr100 gaming router and my 2nd router from the cable company will not connect and everything connected to that router shows its connected still but has no internet…also on the router...
Netduma-Fraser
Jan 22, 2023NetDuma Partner
Just to clarify what is your physical setup? Are you saying your ISP router isn't providing internet or the XR isn't? If your browser forces HTTPS by default that's likely the reason for the error, if you disable this that should disappear.
