Rainslave72
Apr 26, 2019Aspirant
4 K
Is the R7800 capable of handling 4 K streaming , My TV is 4 K , But it doesn't seem to Stream In 4K. Thanks for the Help
Apr 26, 2019Guru - Experienced User
The R7800 is capable of streaming 4k. With that being said, 4k requires consistent higher thoroughput than 1080p. That usually means if there's wireless interference, distance issues, multiple devices streaming at once, you'll probably have issues. I've made sure all my 4k devices are hardwired to prevent the buffering that would happen at my place. I have great signal but so much wireless interference that consistent high thoroughput was a struggle. I could pull 400 mbps on wireless but it wasn't consistent enough.
A couple things you can try.
1. Make sure its on the 5ghz band. It has higher thoroughput than 2.4ghz
2. Do a wireless scan to see if there's unusaged channels you can make sure your 5ghz is on.
3. HVAC, concrete, bricks, and some foil insulation can cause significant signal blockage. Sometimes moving a router a little bit can free up a path to devices and make signals better.
4. high thoroughput devices should be on the 5ghz band and lower thoroughput devices keep on the 2.4ghz.
5. Distance is an issue with any device. 5ghz doesn't reach as far as 2.4ghz. Optimally placing your router in the center of the house can make a big improvement.
What firmware is on your router? How big is your house?
- Rainslave72Apr 26, 2019AspirantFirmware is up to date and less than 20 ft distance
- plemansApr 26, 2019Guru - Experienced User
Which firmware is it?
have you tried changing wireless channels?
20ft should be fine for 5ghz band. Are you connected on that band and using it?
What streaming service are you using?
- Rainslave72Apr 26, 2019AspirantYes on 5 G , Havent changed channels , and sent pic on firmware , RoKu 4 K tv
