Danny80916
Aug 30, 2018Luminary
4k Streaming
 I am at a lose I cant seem to stream 4k movies on vudu. I finally was able to get to stream a 4k movie earlier when i turned off QoS 100% When Qos is on I go to stream a movie and I get a network err...
Netduma-Fraser
Aug 30, 2018NetDuma Partner
What are your bandwidth speeds and what are your QoS settings?
- Danny80916Aug 30, 2018Luminary
Download speed set at 285 usally get 299 on speedtest Bufferbloat set at 73% 204
have ran it with never on have ran it with DumaOS Classified Games on and off Have had bufferbloat set at never have had it set at always. I get the same results unless I turn off Qos also with QoS on blu ray player can't connect to sony to check for updates.
side note HDX movies play fine with QoS on soon as I change to UHD It pops up Network error has happened.
- Netduma-FraserAug 30, 2018NetDuma PartnerMake sure Traffic Prioritization doesn't have DumaOS Classified Games enabled or any manual rules. Use 70% for download/upload on Anti-Bufferbloat and make sure you've put in the speeds you pay for in Anti-Bufferbloat options. Set to Always and on the Geo-Filter make sure the Vudu device isn't added.
