Danny80916
Aug 30, 2018Luminary
4k Streaming
 I am at a lose I cant seem to stream 4k movies on vudu. I finally was able to get to stream a 4k movie earlier when i turned off QoS 100% When Qos is on I go to stream a movie and I get a network err...
Netduma-Fraser
Aug 30, 2018NetDuma Partner
What are your bandwidth speeds and what are your QoS settings?
Danny80916
Download speed set at 285 usally get 299 on speedtest Bufferbloat set at 73% 204
have ran it with never on have ran it with DumaOS Classified Games on and off Have had bufferbloat set at never have had it set at always. I get the same results unless I turn off Qos also with QoS on blu ray player can't connect to sony to check for updates.
- Danny80916Aug 30, 2018Luminary
side note HDX movies play fine with QoS on soon as I change to UHD It pops up Network error has happened.
- Netduma-FraserAug 30, 2018NetDuma PartnerMake sure Traffic Prioritization doesn't have DumaOS Classified Games enabled or any manual rules. Use 70% for download/upload on Anti-Bufferbloat and make sure you've put in the speeds you pay for in Anti-Bufferbloat options. Set to Always and on the Geo-Filter make sure the Vudu device isn't added.
Did that and Turned QoS back on went to stream a movie now Error Unable to stream this movie at the moment due to a network error popped up again. If QoS is off works when on does not even with those settings like you asked.
