Danny80916
Aug 30, 2018Luminary
4k Streaming
I am at a lose I cant seem to stream 4k movies on vudu. I finally was able to get to stream a 4k movie earlier when i turned off QoS 100% When Qos is on I go to stream a movie and I get a network err...
Danny80916
Sep 07, 2018Luminary
ok all done still getting Error the moment QoS is back on
XRaptor29
4K strreaming requires a minimum of 25Mbps. Try setting the 4K streaming device to 25 or 30Mbps download on the QoS.
- Danny80916Sep 07, 2018Luminary
I had it at 200mbs
- XRaptor29Sep 07, 2018LuminaryIs the TV wired or Wireless? If Wireless how far away from the router is it?
Wired have switched cables from cat5e to cat 6 also have done wireless with router about 11 inchs away on 5ghz band with nothing else on that band.
- XRaptor29Sep 07, 2018LuminaryWith QoS on, have you tried rebooting the devices having issues?
yep all 4 of my sony devices are having the same problem with QoS on x800 x700 4k players cant stream 4k or connect to sony update page with QoS on. 900F smart tv 850C smart tv all stutter and buffer constantly with QoS on.
- Netduma_JackSep 08, 2018NetDuma Partner
Hi Danny - sorry these steps did not fix your issue. Do you have any availability next week for a 1-1? Our test engineer will have a look at your router and see if he can figure out what is causing the problem. We are in the UK, so if you are in the USA, morning to mid-afternoon is easier for us.
Thanks.
- Danny80916Sep 08, 2018Luminary
I am off All sunday I usally work till about 5pm est time Tuesday I can do it also if sunday is not good
- Netduma-FraserSep 09, 2018NetDuma PartnerTuesday what time?
- Danny80916Sep 09, 2018Luminary
8am my time what is 10.00 am EST
- Netduma-FraserSep 09, 2018NetDuma PartnerOkay that’s about 3pm UK time, please PM me then
- Danny80916Sep 11, 2018Luminary
I am ready when ever you guys are
