ClassicMuscle
Apr 29, 2019Initiate
5G Network Keeps Disappearing but Reappears With Reboot
My 5G Network keeps disppearing about every 2 weeks. Doesn't show up at all in the SSID list, so all devices go to the 2G Network. But, if I reboot the router via routerlogin.net, the 5G will sudde...
Apr 29, 2019Guru - Experienced User
Is Smart Connect enabled?
Has a factory reset and setup from scratch been done since v40 was applied?
- ClassicMuscleApr 29, 2019Initiate1. Modem is a Spectrum Model E31T2V1 2. I do not have Smart Control enabled. 3. We have a lot of neighbors, maybe 4-5, that show up in my SSID list. Additionally, we have a Ubiquity Hallway access point for devices on the other side of the house and it is broadcasting a different SSID so we can differentiate between it and the Netgear. 4. I have not done a factory reset, no. I am afraid to do so because we have a "smart home" via Savant and I'm concerned it will mess up all the devices that integrated into it. I appreciate the response and help here. Do you think enabling Smart Control will help or hurt my problem?
- FURRYe38Apr 29, 2019Guru - Experienced User
I would try SC enabled.
Also if you have another wifi broadcasting, you need to make sure the channel are far and separate from each other between the XR and this other AP. Having them use same channels can cause this problem. I presume if you temporarily turned off this AP that the XR would work with out problems.
2.4ghz on XR maybe set for 11 and the AP for channel 1. 5Ghz would be 36 or 48 on the XR while the AP should be in the higher channels 149 to 165.
What is the distance between the router and this AP?- Netduma-FraserApr 30, 2019NetDuma PartnerTry SC as suggested, you'll be able to see the devices connected to 5/2.4 on the Device Manager and they'll switch to what is necessary depending on their bandwidth needs.
