enger
May 26, 2020Tutor
802.11k configuration (and RSSI-triggered de-registration to force sticky clients)
I have an R7800. It operates in AP mode. I also have a new ASUS RT-AX89X on the same LAN; it too is set to operate in AP mode. They are both configured to the same SSID. 801.11k Question T...
May 26, 2020Guru - Experienced User
Please post about this here for your model router:
https://community.netgear.com/t5/Nighthawk-WiFi-Routers/bd-p/home-wifi-routers-nighthawk
You might try Voxels 3rd party FW as well.
https://www.smallnetbuilder.com/wireless/wireless-features/33195-wi-fi-roaming-secrets-revealed
https://www.smallnetbuilder.com/basics/wireless-basics/33180-how-to-fix-wi-fi-roaming
Good Luck.
