BowlOfHygieia's avatar
Jul 19, 2019
A problem with dumaos
Hi
I recently bought the XR300 and did all the setup includin geo filter, but when i changed the geo filter settings and rebooted the router I got this message whenever I enter the dumaos on my router :
You are no longer connected to your router. If your router is rebooting then keep this page open as it will automatically reconnect to the router's interface when the reboot is complete. Otherwise please check your connection e.g. you are connected to the correct router.
Any solutions ?
1 Reply
  • Could you try accessing the router via a different method? For example, if you were using routerlogin.net, you could try using 192.168.1.1
