JKirk10
Apr 19, 2020Tutor
AC1900 Router with 24 x 8 DOCSIS 3.0 Cable Modem keeps dropping connection
Good afternoon, So, for the last few months (before the COVID work-at-home overloading networks), my internet has been dropping out. At this point, it's a near-daily thing. Both hardwire and Wi-F...
Apr 19, 2020Guru - Experienced User
1. what router do you have? AC1900 is a speed, not a model.
2. what firmware is on the router?
3. What modem are you using?
Easy check if its the modem? directly connect a device to the modem. Use it. If it doesn't drop and stays stable with good speeds, its probably not the line or the modem.
JKirk10
Apr 19, 2020Tutor
1. Model is C7000v2 (I apologize for the oversight)
2. V1.03.01?
3. It's a Modem/Router (an answer I'm sure you could have reached had I not forgotten to put that in. Again, I'm terribly sorry about that)
- plemansApr 19, 2020Guru - Experienced User
Do you have any screen snips of your modem's cable connection page?
As well as your logs?
When the router goes out, does both wired and wireless devices drop?
Any amplifiers hooked to the C7000?
What devices are hardwired into the C7000?
- JKirk10Apr 19, 2020Tutor
I don't know how to add more than one picture in this post, so i'll add the following three after this one in seperate posts :/ (Again, I'm sorry. NOT tech savvy in the slightlest.)
Both wired and wireless drop
No amplifiers
One PC and one gaming console (PS4 if thats required)
