MaineBear
Dec 29, 2020Aspirant
AC1900 vs AX5400 gaming router
 I currently have the AC1900 Nighthawk router.  A friend told me I should upgrade to the AX5400 gaming router.  What differences in performace will I see in the two and what other differences will the...
Dec 29, 2020Guru - Experienced User
Is the $ worth it? Depends. You might get some lower latency/ping times. You can also choose gaming servers to help with that.
but is it worth the money? That's a loaded question that usually a significant other is better positioned to help with. :)
If you're streaming/gaming devices aren't hardwired in, you might find a better benefit from hardwiring in devices than upgrading its wireless. since I doubt the tv's or shields are AX devices.
are you having issues? Or just curious?
- MaineBearDec 29, 2020AspirantWe aren't really having any problems, so I guess just curious. LOL. We do have an issue with quite high latency. - plemansDec 29, 2020Guru - Experienced UserWhat router and modem/gateway do you have- MaineBearDec 29, 2020AspirantI have Spectrum internet with a Hitreon Docsis 3.1 Modem and the AC1900 Nighthawk router. The internet speed is suposed to be - Download speeds from 100-400 Mbps
- Upload speeds from 5-20 Mbps
 I ran a speed test on DSL report and got these results.... 151 download 23.6 upload 70 ms ping
