MaineBear
Dec 29, 2020Aspirant
AC1900 vs AX5400 gaming router
I currently have the AC1900 Nighthawk router. A friend told me I should upgrade to the AX5400 gaming router. What differences in performace will I see in the two and what other differences will the...
Dec 29, 2020Guru - Experienced User
Is the $ worth it? Depends. You might get some lower latency/ping times. You can also choose gaming servers to help with that.
but is it worth the money? That's a loaded question that usually a significant other is better positioned to help with. :)
If you're streaming/gaming devices aren't hardwired in, you might find a better benefit from hardwiring in devices than upgrading its wireless. since I doubt the tv's or shields are AX devices.
are you having issues? Or just curious?
MaineBear
We aren't really having any problems, so I guess just curious. LOL. We do have an issue with quite high latency.
- plemansDec 29, 2020Guru - Experienced UserWhat router and modem/gateway do you have
- MaineBearDec 29, 2020Aspirant
I have Spectrum internet with a Hitreon Docsis 3.1 Modem and the AC1900 Nighthawk router.
The internet speed is suposed to be
- Download speeds from 100-400 Mbps
- Upload speeds from 5-20 Mbps
I ran a speed test on DSL report and got these results....
151 download
23.6 upload
70 ms ping
As much as I despise spectrum (and cox/comcast to be truthful), they actually do a fairly reasonable job of getting full speed to their modems.
What speed do you get directly connected to the modem?
If you're paying for "up to 400mbps", they can usually hit that without issues.
And AC1900 is a speed, not a model. What router do you have?
What firmware is on it?
