MaineBear
Dec 29, 2020Aspirant
AC1900 vs AX5400 gaming router
I currently have the AC1900 Nighthawk router. A friend told me I should upgrade to the AX5400 gaming router. What differences in performace will I see in the two and what other differences will the...
MaineBear
We aren't really having any problems, so I guess just curious. LOL. We do have an issue with quite high latency.
Dec 29, 2020Guru - Experienced User
What router and modem/gateway do you have
- MaineBearDec 29, 2020Aspirant
I have Spectrum internet with a Hitreon Docsis 3.1 Modem and the AC1900 Nighthawk router.
The internet speed is suposed to be
- Download speeds from 100-400 Mbps
- Upload speeds from 5-20 Mbps
I ran a speed test on DSL report and got these results....
151 download
23.6 upload
70 ms ping
- plemansDec 29, 2020Guru - Experienced User
As much as I despise spectrum (and cox/comcast to be truthful), they actually do a fairly reasonable job of getting full speed to their modems.
What speed do you get directly connected to the modem?
If you're paying for "up to 400mbps", they can usually hit that without issues.
And AC1900 is a speed, not a model. What router do you have?
What firmware is on it?
- MaineBearDec 30, 2020Aspirant
It is the Nighthawk model R7000 with firmware version 1.0.11.110.
I haven't had a chance to test the speed connected directly to the modem.
