Aje
May 28, 2018Guide
Access Control doesn't Control Access
Just finished setting up my XR500 and as a final step I'd like to enable access control, but I can't find it anywhere in the setting?
Can someone please guide me through the configurations menu to ...
Netduma-Fraser
May 29, 2018NetDuma Partner
Hi Aje,
This feature was present up until the last firmware I believe. There was a bug that needed to be fixed with it but the feature was removed instead for some reason. I'm unsure if it will return once the bug has been fixed or not.
