Akonin's avatar
Akonin
Access control XR500 Duma OS
Ok..I can't find the Access control in my new XR500. I use Access control extensebly in my old netgear to keep everyone out from my wireless network to only that equipment I give permission. I need ...
  • Netduma-Fraser's avatar
    Dec 03, 2021
    As above it is not currently available. There is a sort of workaround that you could try, not sure if it will fit your needs or not but you can make a Traffic Controller rule to apply to ALL devices, then block at all times. You can then make individual rules for devices that you want to have internet access, as long as those individual rules are above the block rule they will supersede it and any new devices trying to connect that you haven't made an individual rule for will be blocked.
