Akonin
Dec 03, 2021Aspirant
Access control XR500 Duma OS
Ok..I can't find the Access control in my new XR500. I use Access control extensebly in my old netgear to keep everyone out from my wireless network to only that equipment I give permission. I need ...
- Dec 03, 2021As above it is not currently available. There is a sort of workaround that you could try, not sure if it will fit your needs or not but you can make a Traffic Controller rule to apply to ALL devices, then block at all times. You can then make individual rules for devices that you want to have internet access, as long as those individual rules are above the block rule they will supersede it and any new devices trying to connect that you haven't made an individual rule for will be blocked.
Netduma-Fraser
Dec 03, 2021NetDuma Partner
Akonin
Thanks you very much for responding. I find access control necessary. Everyday I find like 15 different equipment of all sort trying to connect to my router. Acess control is like a second layer of security. In my area is not just necessary but a security saver for my network.
Thanks again I guess I'm returning the router unless I find another OS that can run in it.
