Wyzfar
Apr 13, 2019Aspirant
Access point
Hello I am wondering if it’s possible to use my netduma xr500 as a access point where it’s not connected through WiFi and have it be connected via Ethernet to my modem/router combo and still have the ...
Wyzfar
Ok so scratch last question. I understand why it would be confusing I put some thought into it, I can put my modem in bridge mode yes I have a new question though would it also be better to use my modems Mac Address I have read about how sometimes bridge mode modem mode etc isn’t actually true modem mode so they use there modems MAC address
Apr 13, 2019Guru - Experienced User
Well you haven't said what your modern is so rough to tell. Best advice is if it's supplied by your ISP to contact them and have them help you put it in correct mode for using your xr500 as router
- Netduma_JackApr 15, 2019NetDuma Partner
If you have a working Internet connection through your XR500 when the modem's in bridge/modem mode, then I wouldn't go configuring anything else e.g. trying MAC cloning. Might end up doing more harm than good!
