arees0921
Aug 04, 2019Tutor
Accessing X8000 Settings when set as Access Point
I bought a XR700 and added my X8000 to the same network as an access point. I noticed today that I have all the SSIDs from the X8000 showing up on my available network list and want to go into the X...
Aug 04, 2019Guru - Experienced User
A couple ways to try.
1. connect to the extender either via wifi or ethernet. Type in mywifiext.net
2. Look in the XR700's attached devices list. It should list the ip address for the ex8000. Use this to access it.
Here's the manual for the ex8000 and the XR700
https://www.netgear.com/support/product/EX8000
https://www.netgear.com/support/product/XR700.aspx
Try these and let us know if they work
arees0921
Aug 04, 2019Tutor
Thanks plemans!
I have not found a way to see 'connected devices' using the routerlogin.net tool that works with the XR700 and instead used the DumaOS tool which shows the network map. I can see the x6 on the map and it say that the IP is 10.0.0.8 - cannot click on it - however when I type that adddress into my browser, it eventuall times out and says, "Can't reach this page". I really have no way to know if the x6 is acting like and access point to the XR700 or not at this point.
