Hunter_NX
Jun 04, 2019Aspirant
Acheter un r7000
J'aimerais acheter un routeur r7000 mais je voudrais savoir si celui ci permettera de diminuer les pertes de paquets ?
Jun 04, 2019Guru - Experienced User
en anglais s'il vous plaît
Please post about this here for your model router:
https://community.netgear.com/t5/Nighthawk-WiFi-Routers/bd-p/home-wifi-routers-nighthawk
You might try Voxels 3rd party FW as well.
Good Luck.
Hunter_NX wrote:J'aimerais acheter un routeur r7000 mais je voudrais savoir si celui ci permettera de diminuer les pertes de paquets ?
Hunter_NX
Sorry i thought i was in a french forum.
Do you think the r7000 will resolve my loss packet problem
- FURRYe38Jun 04, 2019Guru - Experienced User
Packet loss can be anywhere, ISP services, Modem, router, WiFi, Cabling or PC.
Use pingplotter.com program to check for packet loss between PC and ISP services. Test with PC directly connected to modem, then again with a router connected.
- Hunter_NXJun 04, 2019Aspirant
- Sorry but you didn't understand. I didn't have the router I want to know if the router will solved my problem
Something you'll have to try. However again, if you have issues before hand, you need to identify where they are coming from other wise change to a different router may not solve anything.
