Kevin1199
Mar 24, 2019Guide
ADD NIGHTHAWK XR500
New Firmware Update Requests:
- Ability to add WAN IP to DMZ (similar to NetDuma campability)
- Ability to add PS4 console as a prioritization
- Game console misspelling under QOS tab / Traffi...
Kevin1199
Apr 06, 2019Guide
Hey there,
So I plugged up my Netduma R1 this weekend and you are correct about it not having DMZ settings, what I had on my mind at that time was with setting up DMZ within the modem and not the router, since I have been discussing different settings with my Modem manufacturer.
With using Duma Classified Games for QOS I'm not too sure which settings are better. I have been placing ports inside the QOS instead and it seems to have worked better than the Duma Classified Games or Games Console options unless I am mistaken.
Netduma-Fraser
Apr 07, 2019NetDuma Partner
If ports seem to be working better for you then use them, as long as they're not causing you any adverse affects. We encourage experimentation, every connection is different, whatever works for you!
- Kevin1199Apr 07, 2019Guide
Now the router won't login to the configuration page by going to 192.168.1.1
I tried resetting by pressing the reset button on the back but that was a no go...
What can I do to fix this?
- Netduma-FraserApr 07, 2019NetDuma PartnerHave you changed your LAN IP? Also try accessing via routerlogin.net
Hold the reset button down for 20-30 seconds and it'll reset. - Kevin1199Apr 07, 2019Guide
Ok, got everything working again just had to do a hard reset on the modem. Awesome, hey thank you for all your help!
- Kevin1199Apr 20, 2019Guide
Some devices including two PS4 show offline under device manager eventhough they are online and still very laggy. Please help.
- Netduma-FraserApr 21, 2019NetDuma PartnerShould just be able to do a reboot and that should resolve it.
- TheMattManJul 25, 2019Guide
Ok reboot of router did nothing different. I am still amber on the PS4 and its still getting horrible DL speeds. I can get better speeds with the Spectrum modem/router. It is only doing 30mb with nothing else using bandwidth out of 117mb.
- Netduma-FraserJul 25, 2019NetDuma PartnerAre you having a similar issue as this isn't your original topic. What speeds do you get with other wired devices?
sorry posted on wrong post
