Mikeowhite
Mar 03, 2021Aspirant
adding additional wireless router to XR500
Last year I purchased an XR500 wirless router to replace my old wireless router. Is it possible to use the old router as a range extender using a wired port to the wired input on the old router?
Netduma-Fraser
Mar 03, 2021NetDuma Partner
As has been mentioned, you can use it as an additional WiFi point, but not as an extender per se.
