ash11
Oct 20, 2022Follower
ADSL vs VDSL
I have installed FTTP will the Nighthawk XR500 AC2600 be compatible with FTTP i would hate it to be incompatable ?
- Yes it's compatible with all connection types, as long as you're able to connect it to an existing modem/router/ONT it will work
1 Reply
- Netduma-FraserNetDuma PartnerYes it's compatible with all connection types, as long as you're able to connect it to an existing modem/router/ONT it will work
