rolly1180's avatar
rolly1180
Am I supposed to turn off Traffic Prioritization if I have forwarded my ports?
Hi all,    So I went ahead and did port forwarding for the game I play (CoD WW2 on console). I'm just curious if by doing that, am I also supposed to turn off the Traffic Prioritization in the QoS...
  • Netduma-Fraser's avatar
    Netduma-Fraser
    Jun 09, 2020
    The two features are independent of each other, so you can use both at the same time. If you want to use the advanced method then leave the source ports default (1-65535) and then just put in the destination ports - the same ones you used for port forwarding.
