SideFX
Oct 26, 2021Aspirant
Amazon and Ring apps not loading properly on wifi XR500
I've had this issue with my pixel 4a and now my s21 Randomly the amazon and ring apps would stop loading properly when connected to wifi but work fine on LTE Suddenly I won't be able to load my ...
Netduma-Fraser
Oct 26, 2021NetDuma Partner
Disable the protection options in WAN Settings, it may be they're dropping packets for those devices.
- SideFXOct 26, 2021AspirantI will take a look and report back.
Thank you.
So I only have the following two enabled
Disable IGMP proxy in and Disable SIP ALG under NAT filtering which is set to Secured
MTU is 1500- Netduma-FraserOct 26, 2021NetDuma PartnerSet NAT Filtering to Open just in case it is a port issue
