EnVy_Hype
May 08, 2019Aspirant
Android Nighthawk app remote management not working
Hi,
I have had lots of issues with the nighthawk android app. It was working perfectly fine the first time I used the app. However, it stopped working for a while and did not let me access my X...
Netduma_Jack
May 08, 2019NetDuma Partner
Instead of using the Nighthawk app, have you tried setting your router up using the web interface?
Go to www.routerlogin.net - username is admin - password is whatever you specified upon first setup
If you want to use the app and are still having problems, try asking in this forum section which is specifically about the app:
https://community.netgear.com/t5/Nighthawk-App/bd-p/en-home-networking-apps
- EnVy_HypeMay 09, 2019Aspirant
Remote management also does not work on duma os.
- schumakuMay 09, 2019Guru - Experienced User
That is a complete different beast - unrelated to the Nighthawk App Remote access via the Netgear cloud ... the Remote Access (as described e.g. in the Nighthawk XR700 Gaming Router User Manual, p.131 ff. under the title "Manage Remote Access" would allow to make the router reachable over it's public IP address on the WAN/Internet interface, on a dedicated port, by https. For this part, there is a step by step configuration in the fine manual, so you might want to explain what you have configured, how you tested, what problems and issues you see ...
- Netduma-FraserMay 09, 2019NetDuma PartnerPlease check again after doing the above, should be able to connect using your public IP in a web browser followed by the port on the Remote Management screen
