EnVy_Hype
May 07, 2019Aspirant
Android Nighthawk app remote management not working
Hi,
I have had lots of issues with the nighthawk android app. It was working perfectly fine the first time I used the app. However, it stopped working for a while and did not let me access my X...
schumaku
May 08, 2019Guru - Experienced User
EnVy_Hype wrote:
I could acess my router via local connection with the app now, but whenever I enable remote management it keeps disabling it after a few seconds.
Typically a volatile issue, can be caused of the router can't link up to the Netgear cloud infrastructure (DNS issue, service down, ...). Or the kids (not yours - ...) were playing again.
EnVy_Hype
May 08, 2019Aspirant
So how would i fix it?
