EnVy_Hype
May 08, 2019Aspirant
Android Nighthawk app remote management not working
Hi,
I have had lots of issues with the nighthawk android app. It was working perfectly fine the first time I used the app. However, it stopped working for a while and did not let me access my X...
schumaku
May 09, 2019Guru - Experienced User
EnVy_Hype wrote:
Remote management also does not work on duma os.
That is a complete different beast - unrelated to the Nighthawk App Remote access via the Netgear cloud ... the Remote Access (as described e.g. in the Nighthawk XR700 Gaming Router User Manual, p.131 ff. under the title "Manage Remote Access" would allow to make the router reachable over it's public IP address on the WAN/Internet interface, on a dedicated port, by https. For this part, there is a step by step configuration in the fine manual, so you might want to explain what you have configured, how you tested, what problems and issues you see ...
Netduma-Fraser
May 09, 2019NetDuma Partner
Please check again after doing the above, should be able to connect using your public IP in a web browser followed by the port on the Remote Management screen
- EnVy_HypeMay 10, 2019Aspirant
Netduma-Fraser wrote:
Please check again after doing the above, should be able to connect using your public IP in a web browser followed by the port on the Remote Management screen.I can't access it. I just can't. It was setup to a proper ip and the 8563.
