bacevedo
Apr 13, 2020NETGEAR Employee Retired
Announcement: New DumaOS Feature - Application QoS
In 2014 we built QoS to reduce lag caused by devices around the home. Whether someone is watching Netflix while you're gaming or a Skype call is raising your ping, we want to let your devices ...
RamboJoe
Aug 22, 2020Tutor
Hey guys I love the amazing work you are doing with these gaming routers, any word if ipv6 will be addresed with upcoming firmwares?. Sorry if this has been addresed already but the issue is when i have qos enabled with the recommended slinders set at 70/70 anti-blufferbloat doesn't work with Xbox. The xbox recieves full speeds and the only way for anti-blufferbloat to work is to turn off ipv6 but Xbox team highly recommend to use ipv6. Thank you guys for everything you do, I'm loving my XR500 looking forward to all these new features.
Netduma-Fraser
Aug 23, 2020NetDuma Partner
Yes we will be getting IPv6 working correctly with QoS. IPv6 certainly isn't required from Xbox and any benefit you would gain is negligible.
