bacevedo
Jul 15, 2019NETGEAR Employee Retired
Announcing the XRM570 Nighthawk Pro Gaming WiFi Mesh System
Hey Nighthawks,
Our Nighthawk Pro Gaming line of routers are the standard that pro and amateur gamers use around the world. With the powerful Duma OS, the Nighthawk Pro Gaming line has h...
Netduma_Alex
Jul 16, 2019NetDuma Partner
Sweet! This is a great solution. So this new Wifi system is like an add on to the existing model? Can you buy the add-on seperately to extend your network if you already have an XR500? And can you use multiple add-ons to create a wider mesh?
- FURRYe38Jul 16, 2019Guru - Experienced User
Ya you can buy the EX8000 or EX7700 as add-on. Not sure how many you could add on though. Like Orbi, they support up to 3 extenders officially. Users have posted having 6. Though the XR are only dual band routers, sans the XR700, the EX are tri band extenders. Would be interesting to see how many an XR would handle. My one does great with the XR450.
Netduma_Alex wrote:Sweet! This is a great solution. So this new Wifi system is like an add on to the existing model? Can you buy the add-on seperately to extend your network if you already have an XR500? And can you use multiple add-ons to create a wider mesh?
