P111
Oct 30, 2018Luminary
Another Problem? What am I doing wrong?
 OK, having discovered that the XR500 has an exhaustive list of 14 games and that I need to set up my other 886 games manaully, which I don't understand how to do, and I would have been just as well o...
P111
Thank you.
I tried a number of browsers and yes you seem to be right that this another bug I have fallen over. I should be working for Netgear System Test, since apparently all their staff are on holiday! I have also seen this complaint for other types of Netgear router, seems to be a pretty common problem. It certainly would help if they fixed it for this one.
Netduma-Fraser
Oct 30, 2018NetDuma Partner
The UPnP table wouldn't be a good one to go off as it may not show all the ports at the time as only opens what it requested. You literally just need to type in the game + ports into Google or use this website instead: https://portforward.com/fortnite/
Some users are experiencing issues with UPnP populating the table even though it does work. Netgear devs are aware
