Eagleq8's avatar
Eagleq8
Tutor
Sep 16, 2020
Anti-Bufferbloat not working on upload speed
Hello.
I have a problem with the anti-bufferbloat. It does not limit the upload speed when I am playing a game even though it is working perfectly on limiting the download speed. I have searched for this problem and saw many posts regarding it and it was acknowledged as a bug and that it will be fixed with version 3.0. I have just updated to 3.0 and the problem still persists which sucks because anti-bufferbloat is basically the reason I bought the router. My cousin has the same router, ISP and download/upload speed as me and his is working completely fine. Any idea on how to fix this problem?
Thanks
  • Please post about this in the beta section and let us know what your connection type is e.g. using IPv6, VLAN, PPPoE, DHCP identifiers
    • Eagleq8's avatar
      Eagleq8
      Tutor
      I did a factory reset after updating to 3.0 and now it works perfectly! Very good update. Thanks
