Alewi
Oct 30, 2019Apprentice
Anti bufferbloat's Upload slider doesn't give any effect!
Good evening, Three days ago, I bought the xr500. I connected it to my modem wich is speed port smart provided from my ISP( Deutche Telekom). The anti bufferbloat's upload slider doesn't give any eff...
- Oct 31, 2019Just an idea, if the ISP router doesn't have DMZ, it should have port forwarding, is that right? If so, port forward 1-65535 TCP/UDP to the XR500, that is basically what the DMZ does anyway. Then also disable the WiFi on the ISP router so all devices can connect to the XR500 and can be controlled by it.
Netduma-Fraser
Oct 30, 2019NetDuma Partner
VLAN may be the cause here. Is there anyway for you to put the ISP hub into router mode and then the XR500 into its DMZ instead? If so that will probably resolve the issue and still allow you to get an open NAT.
Alewi
Thanks for answering.
I suspected that the vlan tagging is the problem. I can set my ISP router in router mode, but it has no DMZ! I had an asus Gt-ac5300 before the xr500 and it was connected to my ISP modem, I was able to limit the bandwidth on download and upload without any broplem and everything was just great. I sold it and got the xr500 due to geofilter function, then I just have this upload slider problem. Is it possible that a new firmware update will solve the problem?
