Fouadsoft
Jan 05, 2020Tutor
Any news about AX gaming router?
Hi I wrote a long post asking for this and provide a suggestion to have DSL/Cable toogle option and I was waiting for answer but suddenly i'm not able to find my topic!? Is it deleted and why?? I ma...
Fouadsoft
Jan 07, 2020Tutor
No this is not my post.
I searched for my post and didn't find it anywhere.
And i'm asking in gaming router section as it is my concern to have ax version for it and to have DSL input as well as WAN port with switch option.
Could i have an answer to my questions that was detailed described in original post that removed for unknow reasin for me.
Netduma-Fraser
Jan 07, 2020NetDuma Partner
Sorry my apologies, clicked on the wrong link in your profile. I can't see the post either, I'm not a moderator but either it didn't post or a moderator has removed it. Unfortunately I don't have access to it. Generally Netgear will not give any information on new/potential products either until one is announced.
- FouadsoftJan 07, 2020TutorIt was posted and have views without reply.
Even they don't say a news why they removing it!
Even to answer me or take my opinion for the DSL/WAN switch option intp consideration.
It wasn't good act by any means.
When asking for both things this means I trust the product but when an act like this sure it is make me confused if to keep this trust or not.
I'm waiting for AX version for the gaming router in addition to the DSL/WAN ports.
Hopefully they listen to that not simply ignore it like just remove a post!
On other side as you are from Netduma i know a new version on the way but i saw a youtube video speak about rate flapping stability in Netgear. Is it resolved or it is on go for new OS.
Also do you provide an upgrade for it regarding all models in case a new hardware model released?- Netduma-FraserJan 07, 2020NetDuma PartnerSorry what issue are you referring to specifically? Any updates we make would be provided on all the routers.
- FouadsoftJan 07, 2020TutorGreat Thanks.
It is 3 videos in youtube showing fluctuations in connection in rx500. You could search by netgear xr500 issues it is first one i think
