usermac
Sep 10, 2018Luminary
Any recomendation on Anti -Bufferbloat with a slow ADSL 20mb down 1mb up settings
Any recomendation on Anti -Bufferbloat with a slow ADSL 20mb down 1mb up settings.
I am currently useing 70-70 on the down and up but my upload being one mega bit could cause an issue.
- Sep 10, 2018I'd leave Bandwidth Allocation alone for the moment. Would suggest using this guide to find the sweet spot for anti bufferbloat http://support.netduma.com/support/solutions/articles/16000074717-test-your-connection
usermac
Going to take a while finding this sweet spot Should I leave it at 70-70 and tweek the distribuition.
USERMAC IS MY GAMING PC
Netduma-Fraser
Sep 10, 2018NetDuma Partner
- usermacSep 11, 2018Luminary
If I am reading this right this anti bufferbloat it reducing ping spikes 95% of the time. On the graph when xbox is off my pc latency is around 11ms and then when I turn the xbox on and start a stream on twich for instance I get hugelatency spikes every 2 and half seconds. I then turn bufferbloat on and the graph stabilizes.
impressive the latency towers when Bufferbloat is off what a difference.
- Netduma_JackSep 11, 2018NetDuma Partner
That sounds about right to me - Anti-Bufferbloat should stabalise your connection when you're streaming, gaming and downloading at the same time. I'm glad it's working correctly!
Anti-Bufferbloat is entirely unique and tailored for gamers and streamers - we reckon it's the best solution out there and hopefully the results speak for themselves :D
looking at the graph it is pen and ink good job
